no brake lights or turn signals
Hey im stuck dont know whats goin on. I have a 2000 blazer turn signals and brake light both dont work. Turn signal indicator lights on dash dont light up either fuses and bulbs r good third brake light however does work. I have already replaced turn signal switch with brand new one and still same problem. Any help greatly appreciated.
Richard, I have a 1997 Blazer and had the same problem. If 1997 and 2000 are the same, there are two flashers to the left of where the cigarette lighter is. The left flasher or relay is for the emergency lights. The right flasher is for the brake lights. I replaced the right one and the brake lights worked. I had to take off the bottom interior trim pcs. off to get to it. The one over gas petal come off first and the center bottom trim second. Then you can get to the flashers. Hope this helps.
Freddie
Freddie
SubbinBlazer
May 24, 2013 12:56 PM
radiorara
Apr 14, 2011 03:04 PM
deltas69
Mar 20, 2009 10:04 PM
