no brake lights or turn signals
Old Dec 24, 2014 | 12:10 PM
Richard Tucker's Avatar
Richard Tucker is on a distinguished road
Default no brake lights or turn signals
Hey im stuck dont know whats goin on. I have a 2000 blazer turn signals and brake light both dont work. Turn signal indicator lights on dash dont light up either fuses and bulbs r good third brake light however does work. I have already replaced turn signal switch with brand new one and still same problem. Any help greatly appreciated.
Old Jun 14, 2015 | 09:09 AM
Freddie's Avatar
Freddie is on a distinguished road
Richard, I have a 1997 Blazer and had the same problem. If 1997 and 2000 are the same, there are two flashers to the left of where the cigarette lighter is. The left flasher or relay is for the emergency lights. The right flasher is for the brake lights. I replaced the right one and the brake lights worked. I had to take off the bottom interior trim pcs. off to get to it. The one over gas petal come off first and the center bottom trim second. Then you can get to the flashers. Hope this helps.
Freddie
Old Aug 10, 2015 | 02:04 AM
Barnard22's Avatar
Barnard22 is on a distinguished road
Did you try testing or swapping the fuse out anyway? I've had fuses go out and look completely fine, like the contact broke inside the fuse 'housing'. Usually happens with constant on/off fuses, like tail/brake lights.
smaiwald
Feb 10, 2014 03:42 PM
gstxtt
Dec 5, 2013 02:56 PM
SubbinBlazer
May 24, 2013 12:56 PM
radiorara
Apr 14, 2011 03:04 PM
deltas69
Mar 20, 2009 10:04 PM
