No head light power
No head light power
I have a 03 Chevy blazer my head lights went out when I turn my lights on my brights symbol come up but none of my front lights come on
Do the (inside bulbs) DRL's, (daytime running lights) work? Did you check the bulbs? Do the (outside bulbs) low beams work?
With the Key ON & headlamp switch ON, remove all 4 headlamp bulbs & check for battery voltage & ground at each headlamp socket. With the headlamp dimmer switch in the low beam position, check the outer sockets. With the headlamp dimmer switch in the high beam position, check the inner sockets. Use a test light or voltmeter. Post your results.
95blaze2dr
Check your fuses. If it is bad and you replace it and it blows after lights are turned on again, you may have a rodent removing coating off wires, causing them to arc together. Or maybe it ate right through light power wire all together. I've seen it happen once. Look for rodent nest up in corners uner hood.
When you click the dimmer switch, does the high beam headlamp symbol on the dash go on and off?
Maybe your ground wire from battery to body came off.
