no lites-ash lites-power windows- or wipers
got in to start up the rig, engine started fine, I had no lights in or out, power windows out, no turn signal lights, no dash lights, no heater fan, radio works
and engine runs fine??? fuse??? if so where is it located.
thanks
thanks
not sure how all this corresponds to each other - the wiper should be on its own circuit - as accessories their own. too so not sure how the radio works when windows dont. - i am guessing you have a burned wiring harness somewhere
Well your fuse box is on the left side of the drivers dash. It will be covered if you have the door shut. They'll be labeled to what they correspond to and check them one at a time. And make sure they're the right fuse amperage. That will be on the inside cover aswell.
Snovelr27
11-19-2017 06:14 PM
argue_with_a_tree
02-28-2011 05:57 AM
