No Low beams
Old May 11, 2014 | 08:34 PM
bobholets's Avatar
bobholets is an unknown quantity at this point
Default No Low beams
I have searched the forums with no luck. I have a 1999 GMC Yukon that is the same as the 1999 Tahoe is that correct? My low beams do not work, My high beams work as well as the DRL work. I believe the DRL's are the same bulb as the low beams just lower voltage. I replaced the switch on the dash. I checked the fuses inside vehicle and under the hood and all are good. There are no relays for low beam. I looked at the low beam bulbs and they look intact. Can anyone give me a idea on a fix? Do I need a new dimmer switch I hope not becase that switch is $200.00 and unless I know it is bad I don't have money to rule that out
Thanks Bob
1998LT
Apr 1, 2011 01:07 PM
portcqb
Oct 5, 2008 07:22 PM
blazerlt01
Apr 12, 2007 11:29 PM
hurleynewfound16
May 14, 2006 09:46 PM
