No power
Old Apr 22, 2019 | 04:33 PM
Jab470's Avatar
Jab470 is on a distinguished road
Default No power
I just replaced the lower and upper intake manifold gaskets on my 97 chevy blazer, after I put everything back together the truck is not getting no power from the battery. I believe I put all the plugged in all connectors cant find any i havent, the battery is good as well. I need some help with why I'm not getting any power to start the truck.
Old Apr 22, 2019 | 06:29 PM
cleburne red's Avatar
So, is it cranking but not starting, no crank but the dome lights, radio etc work, or nothing, like the battery isn't hooked up?
Maybe there's some battery fuse you blew inadvertently. Happened to me once changing the alternator on a Honda accord
Old Apr 22, 2019 | 07:16 PM
Jab470's Avatar
Default No power at all
I have no power at all inside I know I'm getting power to as far as the alternator but power to the cab.
Old Apr 22, 2019 | 08:08 PM
Does 97 have a fuse block under the hood? See if you have power there. If not, trace the wire back to the battery. Maybe there's an inline fuse, maybe you pulled something loose
kwalls
Mar 23, 2016 10:01 AM
justsomeguy
Jul 13, 2012 09:39 AM
Senshi09
Oct 22, 2011 06:49 PM
kpmink
Jan 22, 2008 06:32 PM
wostibot
Oct 21, 2006 07:39 PM
