No start after strange possible electrical issue
Old Feb 13, 2013 | 09:58 AM
cloudchaos's Avatar
cloudchaos is on a distinguished road
Default No start after strange possible electrical issue
Yesterday my door locks unlocked and locked, my guages died and came back my abs light came on and the engine lost power and went back to normal. when I got to my destination i got a crank no start and my daytime running lights don't go on when the key is on and my guages do not respond.
any ideas
I was thinking Body Control Module but from what I see on Mitchel on demand there is no BCM on a 1997 Blazer
I was also thinking A ground possibly but last on I saw with that issue (this was a tahoe not a blazer) still ran just not very well
Old Feb 13, 2013 | 12:37 PM
rockp2's Avatar
It sounds like it may be your ignition switch. Check out this link which can help you diagnose. https://blazerforum.com/forum/articl...-switch-33465/
Old Feb 13, 2013 | 08:03 PM
cloudchaos's Avatar
That shouldn't go out after just hitting a bump. No signs of anything failing till I hit a bump
Old Feb 13, 2013 | 08:14 PM
I agree with rock2p
The ignition switch for 1997 is unique to that year. It is known to cause seemingly non-related electrical issues, much like what you're experiencing. I'd start there and check voltage at the ignition switch connector.... several wires, you'll need a schematic and a digital volt ohm meter.
Old Feb 22, 2013 | 03:03 PM
ETWildPlay's Avatar
ETWildPlay is on a distinguished road
Not restricted to 1997's...my 1999 has the same issue. Mechanic has tried lots of stuff (new fuel pump, new starter after he shorted it). I still think it is the ignition switch. Might try that next.
Old Feb 24, 2013 | 08:24 PM
The problem is not unique, it can happen on others year vehicles as well, it's just not as common. The 1997 ignition switch is the only year they used that specific part number, it was redesigned in 1998.
Old Feb 25, 2013 | 04:50 AM
rexazz2's Avatar
check the battery , alternator
Low voltage when the alternator dies can cause weird electrical issues
Old Feb 25, 2013 | 05:31 AM
newguy's Avatar
Do what the hook says
Old Feb 27, 2013 | 10:59 AM
lifted99blazer's Avatar
lifted99blazer is on a distinguished road
Ignition switch had a lot to do with it..I had simular problems I tiik mine out and noticed that the cinnection had fused together..now my intieor lights work. And when you open the diir it chimes..couple other things started to work when it didnt before...just my 2 cents
hogpilot
Mar 4, 2014 10:38 AM
phxjosh
Dec 1, 2013 06:28 PM
Bildo V.
Feb 11, 2013 02:51 PM
corner27
Oct 27, 2010 05:44 PM
hakuna matata
Sep 3, 2008 09:27 PM
