Normal Voltage Reading
My 2002 Blazer volt meter is constantly reading above 14 volts on the instrument panel when the engine is running. I have a new battery and the engine always starts fine. I was wondering what the volt reading should be with the engine running at the battery posts. I don't care if the volt meter is reading high so long as i know what the correct voltage should be. I can measure that myself from time to time.
Thanks,
Ed
Thanks,
Ed
Last edited by hawkster0001; Jan 28, 2012 at 10:12 AM. Reason: need to add year and model
In colder weather, GM alternators will show over 14 v on the dash pretty much always. In warmer/hot weather, it will drop below 14 as underhood temperatures rise. I found last summer that battery V with underhood hot and engine has been running at temp was 13.8 V. Tried on two different cars.
I find the voltmeter on my truck to be pretty darn accurate and I trust it.
Be aware that any voltage over 12.6 read at battery terminals means the alternator is charging the battery.
Sounds good. With minne running I am at 14.88 on my meter. Gauge is about 15 ish so sounds like we are good to go. Getting ready to do a 1000 mile round trip across the UP of Michigan. No place for car trouble in the winter.
2001Blue
Dec 31, 2010 12:16 PM
TheNasty0ne
Dec 7, 2010 03:23 PM
ivannj
Jan 13, 2006 11:47 PM
