O2 wiring has been spliced; resistance changed
Old Aug 8, 2013 | 07:20 PM
immanentize's Avatar
immanentize is on a distinguished road
Default O2 wiring has been spliced; resistance changed
Hello I joined this forum a few months ago and I have searched and read to no avail. I have a 2002 half year, aka no external egr can, 4x4 4door 4.3l. I'm throwing the heater sensor po135/155 or bank 1&2 sensor 1 codes for sometime and I have narrowed it down,but I need help. I checked with my multimeter for ground and power on both o2's and they are fine. I plugged in my hand scanner and ran the live data for 2min with the key turned but vehicle not started and both o2's do not move outside the bias range by the recommended 150mv. They both stay between 430mv and 490mv; Therefore I checked the wiring to the PCM and each of the 2 wires from the o2 sensors has been spliced halfway en route to the computer. I'm pretty sure at this point that has to be the issue with the probable change in resistance, and if it is I don't know if that is a specific wire type in regards to how its shielded and where to buy it or if I should just go to the junkyard and cut it out from the pcm to the exhaust and pull it. Any input/help or ideas would be much appreciated. This forum has got me this far, therefore I thank everyone in advance either way. Jason
stinz
Mar 1, 2015 10:04 PM
SickRick
Oct 23, 2013 09:40 PM
Klturi421
Jun 7, 2012 10:24 PM
dlippiet
Oct 27, 2010 11:37 PM
Denominator
Sep 13, 2010 04:08 PM
