OBD1 Help
Old Jun 6, 2019 | 10:13 PM
Ironman1257's Avatar
Ironman1257 is on a distinguished road
Default OBD1 Help
So I bought an OBD2 scanner, and an adapter to plug into my '92 Blazer. However when i plugged everything in, the scanner didnt power on. Is there a common issue here??
Old Jun 7, 2019 | 01:14 PM
Could be a blown fuse. Usually, the dome light is on the same one. Maybe the 12V outlet/lighter, too.
Old Jun 7, 2019 | 01:30 PM
I bought a fuse kit and just started replacing all the bad fuses, so I wouldn't think it's that. Although my radio suddenly doesn't work either
Old Jun 7, 2019 | 01:33 PM
If you have a 12-pin connector, you'll have to supply external power. If it's an 18-pin, use a voltmeter to check the B+ terminal for voltage.
Wiring diagram
Old Jun 7, 2019 | 01:47 PM
So, I'm getting power to the connector, around 11v, but it's not turning on the scanner
Old Jun 7, 2019 | 11:25 PM
odat's Avatar
The OBD2 systems supply power to the reader - OBD1 does not
Most code readers need a external power supply as in battery's for OBD1
Mine reader has too have 3 AA battery's added for OBD1
Old Jun 7, 2019 | 11:49 PM
****. I don't think my reader has the option for batteries
Edit: I do not have a way to add batteries 😫
Old Jun 8, 2019 | 12:00 AM
odat's Avatar
Well darn - with my reader the battery's are added in the pig tail for OBD1.
Old Jun 8, 2019 | 12:20 AM
Well. Atleast I've got a reader now and I can take the adapter to autozone
Old Jun 8, 2019 | 10:55 AM
Both of my ancient OBD1 readers have a separate cord that plugs into the cigarette lighter.
