Offroad light on/off switches
What does eveyone use to turn their offroad light switches on and off? Im new to aux lighting and was wondering if getting somthing like this:
http://www.amazon.com/Daystar-KU8001...4948289&sr=1-4
Would be a good idea to get with my lights. Looking at having 4 forward facing and 2 rear facing wired seperately. Any help is appreciated.
That would work. Are you going to use relays?
I got toggle switches in my truck
and its best to use a relay so the wires and the switches dont overload
relays tend to make the lights brighter also
Edit: here is a diagram
Id would not get the power from the fuse box your better off getting it from the battery
What kind or relay would be best for what I want? Links if possible
Actually, I think mine are hooked up with everything Gio said not to do lol.
My switch is tucked up under near the manual shift 4wd is. But mine is wired without a relay and to the fuse block.
But my switch is just a black switch with on/off, it has no light or indicator to tell you it's on.
its ok to get the power from the fuse box but I get the power from the battery to avoid problems in the future (just in case)
Oh, I understand. I just didn't want a clutter of stuff around my battery. The fuse block is so much closer lol. But how much brighter does a relay make the lights? Mine seem to be decently bright the way they are.
i really do not know I fellow forum member told me the relay makes them brighter
I never tryed to see the difference
Relays also allow you to use tiny wire to the switch. Mine are push button computer switches run with 24 gauge cat5 phone cable. I was able to fit 12 in the overhead console. I have my 4 offroad lights on one switch and my fire lights on 2, my siren uses 3, leaving for plenty of more lights to be added later.
