One low beam wont turn on, but both high beams will
All of the lights work except for one low beam headlight. The running lights work just fine but when you flip on the lights only the passenger side headlight works. Although, the high beams work just fine for both headlights which are from the same light bulb. I tried replacing the light bulb first but it did nothing. The drivers side low beam headlight still will not turn on.
Do you know where the ground would be though for the low beam driver side? I am having difficulty hunting it down. There is no power at the plug or before it. (I stabbed a little hole in the wire just to check to make sure it was not the plug) I also replaced the switch on the dash for the lights hoping that would fix it. Although, there is still no power.
1998LT
04-01-2011 01:07 PM
marine
01-28-2010 07:05 PM
