Painless headlite relay # for Quad highbeams
Old Dec 14, 2013 | 09:42 AM
jimspahr@msn.com's Avatar
Default Painless headlite relay # for Quad highbeams
I am looking at the Painless pn 30823 for $63.97 at Summit Racing. This headlight harness with one relay is to make all four headlight stay on for an upgraded highbeam. Any ideas or sources better than Summit Racing or Painless ?
Old Dec 14, 2013 | 10:07 AM
richphotos's Avatar
Old Dec 14, 2013 | 11:53 AM
Rich, I had previously done a search and read that link. I have a 2nd gen and it was confusing to say the least. One guy would say he tried in on his '98 and it worked perfectly. Another guy would say it didn't work on his 2000, Someone else would say he tried in on a 99 and in DRL mode, all four lamps would stay on. Then it would say on the Driver's side H/L cut the yellow wire and send it to ground. Then some one would say : Well, you have to do both sides like that for it to work. These wiring plans have no fuses or Relays in the system. So some one said put a Relay in the mix. That brought up the question of what relay wired in where? And so on. By buying a specific wiring harness from Painless, it would come with instructions and have a fuse and a proper relay.already wired in the harness.
Old Dec 16, 2013 | 10:31 AM
richphotos's Avatar
I think LMC truck might carry them as well. not 100%
Old Dec 16, 2013 | 09:18 PM
Blade_24k's Avatar
Blade_24k is on a distinguished road
i did it on my 2000 and it worked
Old Dec 17, 2013 | 08:45 AM
Blade, which procedure did you do? There are eight pages of different procedures. And does this procedure work on a 2003 two door?
mjsk5blazer
Detailing
Jan 2, 2011 06:49 AM
NorthernCrew454
Jan 26, 2010 11:42 AM
blazedandconfused95
Oct 22, 2009 12:26 PM
greenblazer96
Oct 15, 2009 12:36 PM
bestes
May 31, 2008 03:16 PM
