Parking & fog light bulb replacement????
I guess I'm just plain stupid. I have searched on how to replace FOG light bulbs & could find nothing. So I guess I'm the only one that doesn't know how to do that task.
Can someone please help me out?
Thanks
Thanks
Remove your head light housings to gain access to the back sides of your turn/fog housings. If that doesn't give you sufficient access to the fog light connectors, then you will have to disengage the turn/fog housings from the grill. The attached image shows the tabs (two near the intersection point between the fog & turn cavities) that must be disengaged from the grill in order to remove the turn/fog housing.
carguy798189
11-04-2010 08:25 PM
beastbandit92
08-13-2010 08:24 PM
