Pass Door Has No Power.
Old Jul 28, 2013 | 05:34 PM
Striker911's Avatar
Striker911 is on a distinguished road
Default Pass Door Has No Power.
My 88 K5 Silverado has issues. The power lock switch does not work on the pass side, and the Pass window will not work. So I tested the regulator plug with a test light and tried both drivers and pass window switches for the pass window and I get nothing. I can get the pass door to lock and unlock on the drivers side switch and the drivers window works so it cant be a fuse. Is the switch a common issue? Any other ideas? Thanks.
Old Jul 28, 2013 | 05:57 PM
warthogdriver's Avatar
try a new ground on the pass side from the switch. i had a buddy with and old burban and the harness lost ground connection so he was able to just add a short lead to ground on the door and it worked....may work for you.
Old Jul 30, 2013 | 06:50 PM
Striker911's Avatar
Thanks for the input but if it was the ground the test light should still light up. I tried a few ground locations with the light and never got it to light up. The light also tested good. Guess I will have to follow the power wire when I get time.
jimspahr@msn.com
Oct 30, 2014 08:18 PM
TrTl
Sep 22, 2012 09:56 AM
MikeTastic
Aug 8, 2012 04:41 PM
mr99jimmy
13
Dec 4, 2007 11:57 AM
mr99jimmy
Nov 28, 2007 06:32 PM
