Passlock
I replaced ignition switch with toggle and push button start. I did the 30 passlock relearn at that time and blazer has ran fine ever since. Had an issue and replaced ecm. Instructions that came with ecm say to do passlock relearn. After the ten minutes the security light never goes off. Stays on solid entire time. My question is since I did the relearn before will I have to do again or is it forever
Could you post the steps you did to replace the ignition with the toggle and push button start. I'm having the famous passlock no start issues and the relearn worked for a short time but it's dead in the water now. I have read that you can buy a resistor and hack into the wiring and hook the cut yellow to the black/orange but not sure if that will work. Thanks in advance for any info.
eknox327
25
Dec 13, 2018 11:33 PM
knight1292
Aug 14, 2008 09:30 AM
