Power seat has no power.
Old Aug 26, 2012 | 07:36 AM
TrTl's Avatar
TrTl is on a distinguished road
Default Power seat has no power.
I have power coming out of my harness, but not going into the switch. It wouldn't be a big problem, except the seat was reclined past my memory position when it quit. It had sporadically stopped for a few minutes at a time before it quit and hasn't worked in 3 days. Can anyone tell me if I can jump power to the switch to adjust it until I can find new seats?
Old Aug 26, 2012 | 08:26 AM
warthogdriver's Avatar
i would think is like any other switch...you would have to find out what position/wire does what and wire in a switch of your own.
Old Aug 26, 2012 | 08:40 AM
TrTl's Avatar
Yeah, I was hoping someone on here would know which wires are which. There are what, 6 or 8 switches in the switch box. I am fairly certain I can manage to figure it out. With the wealth of experience on this forum, I decided to see what I can find out, before using the educated guess method.
Old Aug 26, 2012 | 09:57 AM
50lb_cat's Avatar
What I did was grab a battery and a length of wire and hit the motor itself with the hot wire. The motor for the recline is in back of the seat, just pull up the cover. Don't remeber what contact it was as far as up and down.
Old Aug 26, 2012 | 04:59 PM
TrTl's Avatar
Well I had a brain fart when I checked my power leads for the harness. I forgot to check my grounds which is where my problem lies. Now the question is, where on earth do I find where it is supposed to be grounded?
Old Aug 26, 2012 | 06:55 PM
ground it to bolts that hold the seat to the floor if your in a pinch for a ground
Old Sep 22, 2012 | 09:56 AM
drjacobs 63's Avatar
drjacobs 63 is on a distinguished road
Default power seat issues
i have a 96 the wire under the carpet broke like the others, repaired that i now have power going to the switch but seat still will not work, I changed the switch and seat still will not work any ideas
chevylover5
Dec 24, 2013 08:31 AM
kickme005
Sep 6, 2010 06:03 PM
PracticalFitness
Jun 20, 2010 09:07 PM
LilMsChevy
Jan 11, 2010 09:45 PM
khalid_20879
May 30, 2006 12:57 PM
