Projector headlight Questions?
So, My buddy showed me some Headlights on Ebay here.
Black 98 04 Blazer Halo Projector Headlights S10 6 LED Fog DRL Bumper Lamps | eBay
Me and my brother dont know to much about these projector headlights and it says "profesional installation highly reccomeneded"
So it makes me wonder...
What could go wrong?
Is there more to this that i need?
Do i need Ballasts for the Projector?
Are these Legal in Canada?
but yeah, if anyone knows or has any useful information it would be greatly appreciated :3
i have these exact lights. They are made for halogen bulbs, and they are switched to H1 bulbs, but are wired for use with the stock connectors (so plug and play). HIDs can be used in these BUT the hole for the bulb will have to be Dremeled so the bigger HID bulb will fit since the H1 bulb is so tiny. And then you will have to find a way to space back the bulb otherwise the longer HID bulb will have to go under the cut off plate (BAD IDEA! I did this when i first got hids in them HORRIBLE light out put!!!!) But being these projectors are made for halogen, putting HIDs in them the HIDS will not be up to thier full potential, but will still be a ton better then the B.S. H1 bulbs.
I have herd that using Housings with projectors already in them like these makes doing a Projector retro fit alot easier then stock housings (my plan for this summer is to do a Morimoto Mini swap into these housings)
One other complaint i have about these is 4 of the 6 leds burnt out and ive only had them a bit over a year now.
They would be a decent start if you wanted to start a retrofit with good quality HID projectors. The LEDs could be updated as well. I wouldn't expect greatness out of the box though. I'm sure the install will be easy enough.
JLaw
06-14-2007 02:01 AM
