Rear defroster problem
Old Feb 20, 2015 | 10:06 AM
Wamc's Avatar
Wamc is on a distinguished road
Default Rear defroster problem
Mine is showing a .002. What's this mean?
Old Feb 20, 2015 | 11:13 AM
Wamc's Avatar
Not sure if its working or not just purchased the vehicle. Did use frost fighter to reattach a tab to window.
Have voltage to one wire and none to the other.
Ohms is like I said in the previous post.
Old Feb 20, 2015 | 12:10 PM
Wamc's Avatar
Just checked the grid with a check light. Lights up on all grids closest to the drivers side. Further away u go the light gets dimmer and eventually won't light up.
May this be a ground problem?
Old Feb 20, 2015 | 09:38 PM
Here's how to test it:
With the ignition in the RUN position, defroster activated, unplug both wires from the grid. One wire must show battery voltage. The other must show less than 5 ohms resistance to ground. If both of those check OK, and the defroster does not work, the grid has an open circuit.
blazergirl96
Jan 13, 2010 09:49 AM
gserve
Dec 6, 2009 08:33 PM
FlatTopFoley
Feb 10, 2009 08:21 AM
Jerry60k
Dec 20, 2008 05:23 PM
okmomw/blazer
Jun 6, 2006 09:42 PM
