rear pass lights
rear pass lights
they wernet working so i changed the brake bulb witch wasent broken and the rear turn or brake still wont work i checked most fuses and all good all drivers side rear works so now what.
try checking the ground that comes off that socket. does the tail lights work? could be a bad socket itself also. if you have a test light try testing the wires behind the socket to see if there is power going to it
brodieman
06-13-2012 12:36 PM
agent305
08-14-2007 02:33 PM
Moretorque05
03-22-2007 06:04 AM
