roof lighting question..
Old Jun 27, 2013 | 10:43 AM
newguy's Avatar
I took one roof rack bolt out and drilled the hole bigger and ran the wires through there. Then siliconed the hole, no leaks
Old Jun 27, 2013 | 10:44 AM
rexmburns's Avatar
Super Moderator
Just add another relay somewhere under the hood This is where I have all of mine mounted. Its just a piece of thin sheet metal bent to fit and screwed into the fire wall. Everything is convenient and out of the way. I actually have a fourth relay there now as well. The relays are numbered along with the power wires coming off the battery and the switches inside the cab for easy identification.
And heres a shot of the entire engine bay. Nice and clean looking with all of the wires (except one) wrapped nicely in wire loom to keep things clean.
This scares the crap outta me!!! All that wire right at a spot on the door where these trucks are known to be tight fitting and often times rub together. That just looks like way to much potential for an arc to happen and cause a fire to me
Old Jun 27, 2013 | 11:14 AM
bear159's Avatar
bear159 is on a distinguished road
Yeah I know... The hole I had under the luggage rack was to small for the bigger wires so I decided to just run them by the door for now. I will change it at some point this summer because yes, it does not look to safe and it just looks terrible.
Old Jun 28, 2013 | 02:05 PM
Winkler91's Avatar
Winkler91 is on a distinguished road
sorry guys... im livin in a bad weather area right now hoping my blazer dont float away.... its been some serious flooding in my area a lot of the power has been shut down and roads have been closed ... they actually had 3-4 towns shut down because of the flooding
Old Jun 28, 2013 | 02:22 PM
Thogert's Avatar
Well good luck with the weather and stay safe man.
CPLSeraphim
May 20, 2014 05:48 PM
jetboat
Aug 3, 2013 11:57 PM
tibby
Aug 1, 2011 02:14 AM
mjsk5blazer
Nov 29, 2010 08:15 PM
idr
Mar 13, 2006 12:33 PM
