Tail light wiring loom location
Old Mar 2, 2020 | 04:06 PM
Blazinz's Avatar
Blazinz is on a distinguished road
Default Tail light wiring loom location
Can someone point me in the right direction pls. Im looking for the wiring loom that runs between the rear tail lights. I thought it might go over rear door and cant aee wiring or under rear door with electric window ect loom but doesnt appear to be there either..
Old Mar 2, 2020 | 04:19 PM
Believe it comes up from underneath, behind the rear bumper.
Old Mar 2, 2020 | 06:53 PM
Blazinz's Avatar
Thanls for the reply DonL.
I had a look atvthat wiring under rear bumper.
That particular loom has extension to fit trailer plug and the number plate lighting.
I since found tail loght wiring loom.
It is hidden behind a vouple o plastic covers and runs up over rear door glass.
I had to remove a couple of the plastic covers and unplug rear interior light unplug rear glass defroster and rear brake light strip plugs to be able to bring loom out and into a space i can give it a good looking over.
i found an interesting man made nest with a ? Diode fitted between right rear live brake light wire and the black earth wire.
Has anyone encountered this before.
thanks
Thanls for the reply DonL. I had a look atvthat wiring under rear bumper. That particular loom has extension to fit trailer plug and the number plate lighting. I since found tail loght wiring loom. It is hidden behind a vouple o plastic covers and runs up over rear door glass. I had to remove a couple of the plastic covers and unplug rear interior light unplug rear glass defroster and rear brake light strip
Old Mar 2, 2020 | 08:56 PM
That looks like a resistor. Do you have LED tail light bulbs?
Old Mar 2, 2020 | 09:35 PM
Blazinz's Avatar
oh ok. Wondered what it is and why its there.. thanks Tom..
I have a problem with 1 tail light not workin when i push the brakes so tried to find a short and come across this resistor
no LED tail lights either Tom
Old May 9, 2020 | 11:48 PM
mrkevinmjr's Avatar
mrkevinmjr is on a distinguished road
I'm planning on installing led. Gotta find the lines for my resistor.
Cmorehart
May 7, 2015 03:22 PM
haloboy99
Oct 20, 2010 10:53 PM
Blazin1
Jan 12, 2009 08:10 AM
JST4SHO
May 30, 2007 05:43 AM
lowstrung
May 11, 2007 04:52 PM
