Total Ignition Blackout
Old Jul 5, 2011 | 11:01 AM
Strider's Avatar
Strider is on a distinguished road
Question Total Ignition Blackout
This has happened three times in as many days when I try to start my otherwise always faithful '98 4 door, 4wd, 104,000 miles. When I turn the key to the on position, everything is normal. Dash lights come on, ding-ding-ding, etc. When I turn the key to the start position, the truck's entire electrical system goes dead without any sound at all coming from the starter before the blackout. After a few minutes the electrical system comes back. Then when I try to start it, sometimes the same thing happens again and sometimes it starts fine. I researched past threads on this forum before adding this post. Very helpful. I learned that prime suspects are battery cable connections, ignition switch, and starter. I cleaned the battery terminals and cables. There was a tiny bit of corrosion on the positive cable end. I cleaned the grounds to the block and the frame. I did not clean the positive connection to the starter -- too much of bearcat for me to get at lying on my back on the garage floor. The problem continues. Since it happens without any sound of the starter engaging, do you think I'm right in suspecting the ignition switch?
Old Jul 5, 2011 | 11:04 AM
xgiovannix12's Avatar
when you dont have dash lights on or loose power to your radio dash heat/ac . do the starter turn?
Old Jul 5, 2011 | 01:06 PM
Strider's Avatar
When the electrical system goes dead, the starter does not respond at all -- no click, no whir, no nothin'.
Old Jul 5, 2011 | 01:19 PM
yea i think its the ignition switch but do some more research before you change it .
also the 2 above links in my signature has the guide to replace the ignition switch successfully .check that out also .
Old Jul 6, 2011 | 11:27 AM
Strider's Avatar
Thanks for the expertise and the links!
chevylife
Sep 11, 2014 11:31 AM
96blackout
Dec 1, 2011 12:09 AM
rocktheguitarist
Aug 31, 2009 07:29 PM
007jimmy
Jul 10, 2009 10:00 PM
strongboy2005
24
Mar 27, 2006 11:21 AM
