Trailer wiring voltage issue
Old May 23, 2012 | 09:58 PM
thered1's Avatar
thered1 is on a distinguished road
Default Trailer wiring voltage issue
2000 blazer ls loaded, 4wd, 136,000 miles.
While troubleshooting the inoperative lights on my new boat trailer, I discovered that I'm only getting 5 or 6 volts at the brown wire on my harness plug. Voltage on the yellow and brown doesnt have enough time to get to 12 before the relay kicks off, so I've no way to see if they get that high. i removed the harness, which had a fair amount of corrosion, and tested the "good" wire 2' up the harness, and the voltage is still low.
Of note:I have not yet run a separate ground up to the battery to rule out a faulty ground circuit on my massive white wire in the harness bundle, but I will do so tomorrow. ALL FUSES ARE GOOD. I have NOT checked voltage on the "out" side of the fuses, however.
Just looking to see if anyone has encountered this, or has any quick ideas. I will do the above mentioned things tomorrow and see if my results improve.
Thanks, all!
Old May 24, 2012 | 05:43 PM
abig84's Avatar
i would guess ground. especially if all 3 wires arent giving a good signal. just run a long piece of wire from your battery and connect it to the ground and see if that fixes anything
Old May 24, 2012 | 10:00 PM
thered1's Avatar
Ok. Voltage tester battery was dead, giving me faulty readings. My voltage at the plug is fine, but when I plug it into the trailer, nada! NO continuity between green, brown, or yellow and the ground. Continuity between the trailor and the ground wire at plug (meaning the groundwire is properly grounded to frame, and trailer is selfgrounding to ball, I think) this is a tough one! Ill see what im getting for voltage at the various lights tomorrow, see if I can't figure anything out. I just want some damn trailer lights!
Old May 25, 2012 | 06:39 PM
abig84's Avatar
bad connector on the trailer? if its working on the truck and not on the trailer. its something on the trailer side of course lol. check the ground on the trailer. my car trailer, i swear i have to remove clean and rescrew it down like every other year if not more.
Old May 25, 2012 | 07:11 PM
war00's Avatar
war00 is on a distinguished road
sounds like a ground! or the wires are pinched under the tonuge.
phxjosh
Oct 30, 2013 10:03 AM
metroid_killer@hotmail.com
Jan 15, 2012 08:17 AM
2001Blue
Dec 31, 2010 12:16 PM
Rups63
Apr 7, 2006 11:14 AM
trapper_canada
Aug 15, 2005 11:33 PM
