Turn signal arm replacement
Old Jul 10, 2013 | 05:05 PM
Hiero2407's Avatar
Hiero2407 is on a distinguished road
Default Turn signal arm replacement
Does anyone happen to know if a turn signal arm from a 1999 blazer will work in my 1997? I would really rather not have to rip apart everything if it wont
Old Jul 10, 2013 | 06:37 PM
1999 is NOT interchangeable with 1997. On 1997, with and without cruise control are different, and both are ~$300.
Old Jul 10, 2013 | 07:39 PM
4X4GS10B's Avatar
4X4GS10B is on a distinguished road
PNP is also an option
Old Jul 11, 2013 | 07:59 AM
ckroll98's Avatar
ckroll98 is on a distinguished road
I found one on eBay for $72 aftermarket. Works and looks great. Do a search. It's a PITA to change though!
Old Jul 11, 2013 | 04:52 PM
Hiero2407's Avatar
wow.... just wow. Why 300 exactly? i mean i'm doing the work myself so labor isn't an issue.
Thanks ckroll98 I'll have to check that out.
Old Jul 11, 2013 | 05:20 PM
richphotos's Avatar
I have heard that the aftermarket ones (cheaper ones) wear out much faster, and you will be in the same boat as before) I would check a u-pull yard. dirt cheap, you can pull a couple.
Old Jul 11, 2013 | 05:38 PM
In the "good ole days" you could replace just the lever: pull the old one out, push the new one in. Done in 2 seconds!. "Progress" means you have to replace the entire multifunction switch, which entails taking the upper column covers off to get at the dang thing. One good thing about the multifunction switch is now you can replace the hazard switch in 2 seconds! In the "good ole days" it meant removing the steering wheel and replacing the entire turn signal switch.
bradw1984
Nov 27, 2013 08:22 PM
ta3ff
Oct 14, 2009 05:07 PM
Sunshine Coaster
Feb 15, 2008 07:43 PM
RedOctober
Oct 11, 2006 09:00 PM
shaka1111
Feb 13, 2006 02:23 PM
