Turn signal blinks fast...sometimes
Old Nov 23, 2010 | 05:30 PM
EXKid's Avatar
EXKid is on a distinguished road
Default Turn signal blinks fast...sometimes
2001 LT 4x4 4 door.
Sometimes the turn signal clicks fast. I recall in years past that when a bulb burned out, this happened, but such is not the case here. At least not from what I can tell.
Flasher maybe? It happens in both positions, and I just checked to see if it happened with the hazards on and it didn't. So, single signal it happens, then stops if I turn the hazards on.
Old Nov 23, 2010 | 07:35 PM
You could have a corroded connection in one of the bulb sockets causing an intermittent connection mimicking a bulb failure at times.
Old Nov 24, 2010 | 11:17 AM
EXKid's Avatar
good call. I'll check them out.
Old Feb 7, 2011 | 09:19 PM
swedp's Avatar
swedp is on a distinguished road
my flasher relay comes on and off for no reason,turnsignal/hasard working properly.it just tick´s when it likes it,changed relay but same procidier.just wonder what can make it get current? great forum by the way
BigEffingHammer
Jul 18, 2012 10:32 PM
mmontero
May 11, 2012 11:30 AM
lionel2
Sep 19, 2009 04:14 PM
mrmack070
Jul 27, 2009 09:05 AM
scottvwcars
Dec 29, 2006 08:46 PM
