Turn Signals
Hello everyone,
My 94 1500 Blazer is approaching 250k miles and it now requires some TLC.
Recently my turn signals stopped working, no clicking, no lights nothing.
At first my right signal would turn on but not turn off automatically after a turn. Then they both just completely stopped working. I checked my hazards and they still work so what gives? Any clues how to fix this?
Cheers
Cheers
I hate to tell you because it's a real pain, but you probably need a new turn signal switch. Everything runs through it and they do wear out. There really isn't any good way to check it but if things aren't working and your fuses are and bulbs are okay, that's really about all it can be. It's best to have a mechanic do it. Don't blow up your air bag by making a mistake.
the part is called a multi-switch.
you can go junkyard and role the dice for half price or go new...up to you.
here is how to do it....very easy if you are mechanically inclined.
https://blazerforum.com/forum/2nd-ge...-blazer-42797/
keep in mind i did this on a 99 blazer....should be similar with most years.
captaink....nice sig line....very true indeed.
SubbinBlazer
May 24, 2013 12:56 PM
mendez918
Mar 3, 2005 11:42 PM
