Turn Signals
Old Jun 6, 2011 | 01:19 PM
shootsright's Avatar
shootsright is on a distinguished road
Default Turn Signals
Hello everyone,
My 94 1500 Blazer is approaching 250k miles and it now requires some TLC.
Recently my turn signals stopped working, no clicking, no lights nothing.
At first my right signal would turn on but not turn off automatically after a turn. Then they both just completely stopped working. I checked my hazards and they still work so what gives? Any clues how to fix this?
Cheers
Old Jun 6, 2011 | 08:10 PM
96jimmyslt4x4's Avatar
96jimmyslt4x4 is on a distinguished road
Try replacing the relay.
Check all the fuses.
Check the hazard stuff as well.
Could be the wiring to the switch that activates the blinkers.
You just have to look around
Old Jul 11, 2011 | 01:57 PM
Chenzo's Avatar
Chenzo is on a distinguished road
my 92 s10 is doing the same thing. relay and fuse is good. any ideas?
Old Aug 11, 2011 | 08:29 PM
CaptainK's Avatar
CaptainK is on a distinguished road
I hate to tell you because it's a real pain, but you probably need a new turn signal switch. Everything runs through it and they do wear out. There really isn't any good way to check it but if things aren't working and your fuses are and bulbs are okay, that's really about all it can be. It's best to have a mechanic do it. Don't blow up your air bag by making a mistake.
Old Aug 11, 2011 | 08:38 PM
warthogdriver's Avatar
the part is called a multi-switch.
you can go junkyard and role the dice for half price or go new...up to you.
here is how to do it....very easy if you are mechanically inclined.
https://blazerforum.com/forum/2nd-ge...-blazer-42797/
keep in mind i did this on a 99 blazer....should be similar with most years.
captaink....nice sig line....very true indeed.
SubbinBlazer
May 24, 2013 12:56 PM
BlaZeR FXB1581
Jan 22, 2006 11:51 AM
BlaZeR FXB1581
Sep 2, 2005 07:41 PM
mendez918
Mar 3, 2005 11:42 PM
blazin97
Feb 22, 2005 01:49 AM
