volt drop
Old Nov 23, 2011 | 08:59 AM
ldtiv's Avatar
ldtiv is on a distinguished road
Exclamation volt drop
'97 Blazer with a new battery and a bench tested alternator (it passed) but when you press the accelerator the volts (dash gauge) drop from 14v to as low as 9v. Any ideas what could be wrong?
Old Nov 23, 2011 | 10:00 AM
br1dzies's Avatar
br1dzies is on a distinguished road
Default Same Thing
I have a 1998 that is doing the same thing, the voltage drops when the gas is pressed, and then when idling at a stop light, it replenishes.
Old Nov 23, 2011 | 02:48 PM
appliancguy's Avatar
appliancguy is on a distinguished road
Just went through this on my 99. Found the wires from the battery to the fuse box and to the alternator were just dust. I was shocked (bada boom) in the condition of these wires. This fixed a few problems I had.
Old Nov 24, 2011 | 11:06 PM
ldtiv's Avatar
Default volt drop
it turns out to be the alt afterall!
Old Nov 28, 2011 | 05:30 PM
Chevysrule5's Avatar
Chevysrule5 is on a distinguished road
im having the same problem right now. i put a new tensioner assembly on it thinking the belt was just slipping and nope... still does it. dont want to just throw an alternator at it next and have it not fix it though. its hard to see the alternator being the issue as it charges perfectly fine driving down the road, only dropping when it downshifts and goes above 3000 rpm, dropping it to around 9 or 10 volts. as soon as it shifts and the rpms drop, it comes right back up to just a hair over 14.
Old Dec 5, 2011 | 03:49 PM
help please!!
AirJer
Feb 11, 2010 01:44 PM
jorge1
Sep 23, 2009 06:09 PM
Numba1Sean
Oct 3, 2008 09:42 AM
S10Blazer
Jul 8, 2008 12:32 PM
zombiewoof
Feb 25, 2008 06:51 PM
