help on installing a volt gauge
Old Oct 2, 2008 | 01:09 PM
Numba1Sean's Avatar
Numba1Sean is an unknown quantity at this point
Default help on installing a volt gauge
just wondering how the wiring is done on this. i had enough of the stock volt gauge, its so wrong its not even funny. battery was reading 14.4 through a volt meter and thegauge was reading around 13.7 i believe. i just know it was below 14 easy on the gauge. if this is the wrong section for this im sorry. so i now believe ppl whe they stock gauges are not always right.
Old Oct 2, 2008 | 04:14 PM
NoPh33rRaCiNg's Avatar
NoPh33rRaCiNg is an unknown quantity at this point
Default RE: help on installing a volt gauge
i have a stinger one, it comes with 3 wires, pos +, neg -, and turn on wire, i just have it ran straight to my amps to monitor them. you can run pos and neg to your front battery, and either use a switch to turn it on, or tap the turn on wire to an accessory that turns on when you start the car. mine use to be mounted at the top of drivers pillar like in this old pic, now i have mine above the rear seatbelt on passenger side.
Old Oct 2, 2008 | 09:19 PM
Numba1Sean's Avatar
i was looking into one of those, thanks for the help man. so is your turn on the remote wire?
Old Oct 2, 2008 | 11:20 PM
yup i just have the three wires of the volt meter directly into my amp
Old Oct 3, 2008 | 12:09 AM
bigjoeblaze's Avatar
bigjoeblaze is an unknown quantity at this point
Got a few Questions. Is this better reader of voltsor is this more for looks? When installing it it hard to hide the wires? What is the easiest way hooking on of this up? Thanks
Old Oct 3, 2008 | 09:42 AM
its not gonna be exact exact but you can adjust it to be pretty close, i used a dmm to tune this stinger one, you can pop the cover off and there is a screw you turn to adjust the reading up or down and match it with what your dmm is reading. when i had it at the top of my pillar like in the picture i just ran the wires behind the pillar, down under the carpet and back to my amp. right now its on the rear passenger side on the plastic above the seatbelt on that pillar, i drilled a hole, mounted it there and ran wires behind that plastic then down to my amp, it was only like a 6 ft run
bigdaddykane93
Nov 7, 2013 08:16 PM
Rselarep
Dec 11, 2011 07:14 AM
jorge1
Sep 23, 2009 06:09 PM
S10Blazer
Jul 8, 2008 12:32 PM
zombiewoof
Feb 25, 2008 06:51 PM
