Voltage Gauge going nutty - Alternator Re-Wire to Voltage Reference
Old 12-28-2010, 11:57 AM
So did this cure your bouncing system voltage?
I will copy this post into the Article Submission/Discussion section in a bit (a little busy at the moment). In the mean time, I did take and include the thumb & link to full res image into the post body for each of the attachments.
Old 12-29-2010, 11:32 AM
2001Blue's Avatar
2001Blue is on a distinguished road
The voltage is much more stable now, I don't have the issue with the turn signals or any random voltage drops when sitting at a light or anything. But I have to figure out what is causing the transmission to not shift until the voltage drops to like the 1/4 mark on the voltage gauge. On hard acceleration the trans wont shift, then you'll see the voltage gauge drop to the 1/4 mark, trans will then shift and voltage gauge will go back to normal.
Old 12-29-2010, 11:38 AM
That doesn't sound good... It's almost like the alternator is shutting down at higher RPMs...
Old 12-31-2010, 12:16 PM
2001Blue's Avatar
Yeah, I am going to see about changing out the alternator, but since I am putting in a system, I am thinking about doing the AD244 upgrade while I am at it.
Adam Stewart
06-05-2014 08:55 AM
er0ck273
09-01-2013 11:45 AM
guywm25
06-30-2008 09:50 AM
bubba181x1
03-12-2008 02:05 AM
sasquatchfound
Suspension Tech
07-10-2007 07:21 PM
Quick Reply: Voltage Gauge going nutty - Alternator Re-Wire to Voltage Reference
