W/S wipers intermittent on a 2003 2 door ?
Old Mar 3, 2020 | 04:07 PM
jimspahr@msn.com's Avatar
Default W/S wipers intermittent on a 2003 2 door ?
This is a comes and goes problem. Everything else in the lighting and ignition work fine all the time. The hazard button, the ignition switch and radio all work on demand. Then the wipers will stop and switching to all positions : delay, on and off, Mist gives nothing. Then it will mysteriously come back on for a few days or weeks and then start this cycle over. Does this rule out the fuse ? Anything else I should check ? What should I check on the w/s wiper motor ?
Old Mar 6, 2020 | 10:28 AM
It would seem to be a w/s wiper motor issue or a connector to the motor issue to be an intermittent problem. If it was a bad fuse, it would be a GO/ No GO situation.
buhlayzah92
Aug 16, 2016 01:08 PM
LoneR
Nov 7, 2012 01:13 PM
crater
Feb 11, 2012 01:37 AM
Greed
Nov 22, 2008 04:10 PM
p72lwor
Oct 23, 2006 09:02 AM
