A way around it?
Old Sep 29, 2018 | 11:27 PM
StarScreamin's Avatar
StarScreamin is on a distinguished road
Default A way around it?
hello,
I'm curious if there is a way to bypass my "lights on" sensor ( in my right dash speaker grill) so that I can let my engine run while it's dark out & not have any of my exterior lights illuminated?
Thanks for any help or info. I appreciate it.
Last edited by StarScreamin; Sep 29, 2018 at 11:32 PM. Reason: I didn't mention the vehicle year. ( 1999 s10 blazer 4x4)
Old Sep 30, 2018 | 12:41 AM
newguy's Avatar
put on the Ebrake
Old Sep 30, 2018 | 03:12 AM
GreenBlazer2002's Avatar
Originally Posted by StarScreamin
hello,
You didn't bother to tell us anything about your blazer, but if you have the button that overrides the interior lights, try pushing it in and out repeatedly a few times. On some models, it will cancel the auto-on feature but only for that key cycle.
Old Sep 30, 2018 | 10:41 PM
AJBert's Avatar
I'll have to look, but you can replace the sensor with a resistor. I forget the exact size as I did 15+ years ago. Bought a few of them from Radio Shack, that tells you how long ago. If I remember I'll take a look tomorrow and let you know.
As for the dome override trick, only works for certain years and you push it in and out four times.
Old Oct 1, 2018 | 05:37 AM
steveduns's Avatar
steveduns is on a distinguished road
On my 2000 Blazer just push dome override 4 times and disables the lights until next time you start it. Here's a link on this forum with some other options.
https://blazerforum.com/forum/2nd-ge...0-blazer-7052/
Old Oct 1, 2018 | 06:31 AM
chevyriders's Avatar
Unplug the sensor, and wire a resistor from one prong to the other.
if you have a 98 you need an 860 ohm resistor.
if it's 99 and up, you need a 2.2k ohm resistor.
Old Oct 1, 2018 | 10:20 PM
AJBert's Avatar
There's the answer! I may still have some of the 2.2 ones in my console.
Old Oct 1, 2018 | 10:38 PM
G0LFADD1CT's Avatar
G0LFADD1CT is an unknown quantity at this point
I'll be picking up a resistor if that's all it takes. I hate having to push the button 4 times every time I get into the rig.
Old Oct 10, 2018 | 07:09 PM
Yes, my apologies for the lack of info concerning my blazer. It's a '99 4x4. And not only do i want my headlights off, I also want the option to shut off all my exterior lighting. If ur wondering why, it's for the simple fact of hunting. I just think it would be great to be able to turn my lights on/off wen I want to.
Old Oct 11, 2018 | 01:45 PM
My 99 4dr is used for hunting too and it would be nice to drive without headlights or only the parking lights when I want. Thanks for bringing up this thread.
Be sure to post your results. Does the Dome Override button trick work on yours?
