Window Wont Roll Up
Old Mar 21, 2011 | 05:20 PM
Little Roober's Avatar
Little Roober is on a distinguished road
Default Window Wont Roll Up
My drivers side front window wont roll up all the way without a lot of help. All the others work fine. Does this mean just the motor needs to be replaced? And is this the correct part? Just makin sure I've got it diagnosed correctly before shellin out cash.
Dorman/Window Lift Motor (742-143) | 1996 GMC Jimmy 4WD 6 Cylinders W 4.3L SFI | AutoZone.com
Thanks.
Old Mar 21, 2011 | 09:27 PM
84BlazerS10's Avatar
Sounds like a bad motor or faulty wiring. Seems like the correct part but you should be able to just ask your auto parts store just to double check.
Old Mar 22, 2011 | 11:52 PM
JandL_03's Avatar
JandL_03 is on a distinguished road
Do you hear the motor atleast trying to turn on? If so, then its not the motor it woudl be the regulator...If you dont hear anything at all...its the motor...also check fuses just in case
Old Mar 23, 2011 | 12:22 AM
It will go up some and will need help after about half way. Some times it works all the way..usually after driving for a while after I've rolled it down.
xfact0r3
May 11, 2013 10:24 PM
dunlap3
Jul 16, 2012 06:14 PM
GP1
Mar 21, 2012 01:34 AM
kwerts
Nov 4, 2009 07:13 AM
burt
Sep 2, 2008 02:15 PM
