2001 4 door 4x4 blazer brake problems
Old Jul 16, 2018 | 09:47 PM
HisHarley1022's Avatar
HisHarley1022 is on a distinguished road
Default 2001 4 door 4x4 blazer brake problems
Hi. I have a 2001 blazer. That I baught off my brother. It had a stuck rear caliper that ended up braking apart the rotor. I have changed rotors calipers pads brake booster and master i have direct connected it bipassing the ABS i get great pressure oit of the master but no fluid to the rear brakes. Im at a loss. What else could it possibly be?
Old Jul 17, 2018 | 07:36 PM
Only thing I can think of is that you hooked the wrong lines that head to the back up to the master cylinder or pinched a line in the process.
On that note, why did you bother bypassing the ABS module assembly? Even if it is non functional it at least acts as a junction block and distributes the brake pressure where it needs to go. And even if it's flipping out and randomly kicking on and engaging the ABS system, just unplug the module until you can get it properly fixed and that should stop that temporarily.
Old Jul 23, 2018 | 05:42 AM
Jon Walter's Avatar
Jon Walter is on a distinguished road
Have question as well
I have a 97 4x4 blazer. For the past 6 months, it has occasional brake failure. I put them on, the peddle goes to the floor and the engine revs up, I go through a stop sign. I took it in and they said it was my Master cylinder, then some type of sensor. It still occurred. It does it maybe once a month. I recently had the ABS booster replaced. It is not made anymore so I got a junk yard part. It was ok for 2 months, then, once again, as I go down a hill like a driveway or exit a parking lot, the brakes fail even with controller, the engine revs up and I nearly get into an accident.
There as got to be a reason. Any suggestions?
bizzs
Oct 2, 2012 03:32 PM
shligger
May 12, 2010 08:47 AM
Thor_449
Mar 27, 2009 12:45 PM
