95 Grand Am No compression
Old Jan 11, 2011 | 09:57 PM
gmbwrenchn's Avatar
gmbwrenchn is an unknown quantity at this point
It never seen extream heat though, enough to blow it.
Old Jan 11, 2011 | 10:02 PM
01vortec's Avatar
01vortec is an unknown quantity at this point
You don't necessarily have to overheat a motor to blow a head gasket.. You may have not torqued the head down properly when it was changed before, causing it to blow.
Old Jan 11, 2011 | 10:08 PM
gmbwrenchn's Avatar
It lasted 5 yrs. from when I replaced it. May have took awhile..true. As were on the subject of head gaskets, I did use a GM head gasket. What do you think about the copper head gasket spray by Permatex? Use..or not use.
Old Jan 11, 2011 | 10:10 PM
01vortec's Avatar
thats more of a sealant than anything. I've never used it, so I really have no input on it.
stress, old age, warped head, any of those can also cause a blown head gasket. Was the head/block machine shaved when you replaced the gasket?
Old Jan 11, 2011 | 10:13 PM
gmbwrenchn's Avatar
Yea had a valve job done as well as the head milled. Not the block. Stoned it best I could.
Old Jan 11, 2011 | 10:14 PM
01vortec's Avatar
those motors are prone to blowing head gaskets anyways. I would say it was about due for one.
Old Jan 11, 2011 | 10:15 PM
gmbwrenchn's Avatar
Thanks....good enough.
Old Feb 20, 2011 | 10:57 AM
gmbwrenchn's Avatar
Ended up being bent valves. Timing chain must have skipped a tooth because the tensioner was defective too. Head was cracked, tossed that, got a new one. Redid everything now. Runs great! Thanks for all the input.
Jharper
Street N Strip
18
Dec 25, 2008 04:37 PM
EuroGoldLS
Dec 1, 2007 01:02 PM
Jharper
Nov 13, 2007 06:18 PM
blazinloud
Sep 28, 2007 12:13 PM
ivannj
Oct 14, 2006 04:40 AM
