cold air intake?
Cold air intakes are a misnomer. There is no cold air in the engine compartment. The only benifit is from most cold air intakes system is because the filter assy. that thery provide is a less restrictive air filter than OEM. You are better off getting a drop in low restrictive air filter such as a K&N air filter. If you looking for results than get a drop in filter. If you just like the look and want to spend the money get a cold air intake system. Why do you think most cars draw the air in from outside of the engine compartment?
The round dishes allow much more air flow than the second generations square air box. So a drop in filter would work great for your set up.
