dodge 2500
Old Mar 9, 2009 | 08:54 PM
Thor_449's Avatar
Thor_449 is an unknown quantity at this point
Default dodge 2500
so my dad owns a 1999 dodge 2500 v-8(gasoline) and it starts realy hard in warm wheather. It won't start at all in cold or wet wheather. we have already tuned it up and changed the air and water temperature sensor in it and it started nice twice then it went back to nothing. the starter is good so is the selenoid. when we try to start it, it advances everything so much that it blows back threw the throttle body. does anybody know whats wrong with this thing? is it a bad timing sensor? worn out chain? it's only got abot 120,000 miles on it and we realy need as my dad drives it to chicago during the week.
Old Mar 9, 2009 | 09:04 PM
If the chain has stretched to the point of jumping the cam to crank timing, it should show up on a compression check. If you rotate the engine over to TDC #1 cylinder, does the distributor rotor point to the #1 tower on the distributor?
Old Mar 11, 2009 | 05:32 PM
Thor_449's Avatar
Well a new symptom that points to the timing chain. luck has it that i got it running and i decided to drive around the block to charge the batterie. i decided to do a stress test and floored it and went nowere....I could here the distributer or something spinning around like mad but all the cylinders started to missfire
Old Mar 11, 2009 | 07:00 PM
If it stayed running, then the noise was coming from someplace other than the distributor or timing set. You would not strip a timing set and still have a running engine.
Old Mar 15, 2009 | 08:49 PM
Thor_449's Avatar
I talked to my dad and we think either fuel filter or some spark sensor....we can't ever remember changing the fuel filter and we are pretty sure it's not the injectors because we ran sea foam threw it not too long ago. but most of the the spark and fuel or emmisions crap that would throw the truck off would happen all the time and this is only on hard acceleration and start up....once agian we don't see the logic of ever leaving carburators
Old Mar 15, 2009 | 09:30 PM
Cavalier z24's Avatar
Cavalier z24 is on a distinguished road
i would change the fuel filter
Old Mar 15, 2009 | 09:54 PM
calgsblaza's Avatar
calgsblaza is an unknown quantity at this point
Lemme guess, it's got the 360 right? Just light it on fire then lol
Old Mar 26, 2009 | 12:32 PM
Thor_449's Avatar
well so now i am stumped. i was looking undernieth for the fuel filter, couldn't find it. looked in the repair book, couldnt find it there either. So i went into the auto parts store just to see what it looked like.......well there was a reason i didn't find it. The fuel filter is integrated in the fuel pump assembly. So if it is clogged can I clean it out or am i going to have to get a whole new fuel pump?
londonmazda
Oct 19, 2010 02:15 AM
garrettdavid
Oct 5, 2010 05:35 PM
adavis12
May 29, 2009 10:32 AM
