Notices
Drl
Old Dec 22, 2017 | 05:24 AM
Moy210tx's Avatar
Moy210tx is on a distinguished road
Default Drl
How do I disable drl 99 Chevrolet blazer
Old Dec 22, 2017 | 06:43 AM
chevyriders's Avatar
I cut the 86 pin off my drl relay in the Underhood fuse box to disable my drls
You also have auto headlights, if you want to disable them as well, unplug the sensor in your rt speaker grille and wire a 2.2k ohm resistor from one side of the plug to the other. That will give you full controkl over your headlights with the switch
Old Dec 22, 2017 | 06:46 AM
Moy210tx's Avatar
Thanks i will try that, do I have to disable auto lights? I want to install hids is the whole reason behind this smh
Old Dec 22, 2017 | 06:49 AM
I don't believe you would have to disable auto lights for that, I just added that in there because 99% of the time when someone asks about disabling the drls, it gets followed up with the auto lights question lol.
Just pull the relay, and look on the bottom for the pin labeled 86. Clip it with a pair of dykes and you should be good to go
Old Dec 22, 2017 | 06:51 AM
Moy210tx's Avatar
lol coo I appreciate it, ima try that in a Bit. I tried the dome button trick and that didn't work. I'll let you know how it goes. Thanks again
Old Dec 22, 2017 | 07:33 AM
Moy210tx's Avatar
just tried that 86 pin and the drl are still on, any other suggestions?
Old Dec 22, 2017 | 08:06 AM
Ahh, that's worked on both of mine I've done it to..
Here's a copy and paste from s10forum. Maybe this will work for you, although 86 alone has always worked for me.
98 and up DRL
Remove the cover on the fuse box under the hood. Locate the DRL relay. Locate pin 87A and 30 on the relay. DO NOT MODIFY PINS 87A OR 30. Bend or cut the other pins off the relay. ( I recommend bending the pin incase you bend the wrong one, you can always straighten it). Then plug the realy back in and check to make sure the DRLs are off and you still have high beams.
Old Dec 22, 2017 | 08:12 AM
Moy210tx's Avatar
98 and up DRL
nope still have drl and high beams
Old Dec 22, 2017 | 08:55 AM
That's strange. Are you sure it's not your auto lights that are on still?
Old Dec 22, 2017 | 09:05 AM
Moy210tx's Avatar
This is going to sound stupid but how do I know the difference?
