headlight adjustment
Old Jun 15, 2009 | 07:39 AM
tprouty's Avatar
tprouty is an unknown quantity at this point
Default headlight adjustment
my headlight is pointing down to the ground and i really cant see anything at night. I found the headlight adjustment screw but when i screw it in it goes no where... I can push it so it goes in but then it just comes back out, so I'm guess what ever it screws into is striped. does anyone know a work around or a place I can get a new housing? I bought projectors, and HIDs are on the way cause the lights suck on this thing and now I just need to point right.
Thanks
found it: Part No. 42119 at Advanced Auto.
Old Jun 15, 2009 | 08:12 PM
AJBert's Avatar
First thing I would do is make sure your light is installed correctly, as in both tabs seated completely.
Old Jun 15, 2009 | 08:51 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
do the 1st gen blazers have the tabs on the headlight?
Old Jun 16, 2009 | 10:16 AM
AJBert's Avatar
Hmmmm...
I don't know if the 1st gens do have the tabs or not???
Old Jun 16, 2009 | 10:23 AM
tprouty's Avatar
This fixed my issue. I also need to go out and buy new Headlight Retainer's as I lost some of the screws lastnight, *damn drunk people bothering you while trying to work*
Old Jun 16, 2009 | 08:23 PM
If you want to aim them to factory spec, here is the aiming screen print:
The height of line 3 is the measurement from the ground to the center of the bulb in the headlamp.
The width of the two vertical lines (#2) is the measurement from the centerline of the car to the center of the headlamps.
You will want to have around a 1/2 tank of fuel.
Old Jun 17, 2009 | 07:16 AM
tprouty's Avatar
awesome! thanks a bunch for that info.
richphotos
Sep 3, 2013 11:31 PM
kaejr
May 22, 2007 01:01 PM
drperry
May 3, 2007 07:50 PM
Chevyguy032
Apr 6, 2007 05:15 AM
rlt7272
Suspension Tech
Mar 9, 2007 02:20 AM
