How to read a Haynes manual (borrowed from Biohazed)
Old Dec 13, 2010 | 06:17 AM
Sturg's Avatar
Sturg is on a distinguished road
Default How to read a Haynes manual (borrowed from Biohazed)
Haynes: Rotate counterclockwise.
Translation: Clamp with vise grips then beat repeatedly with hammer counterclockwise.
Haynes: This is a snug fit.
Translation: Clamp with vise grips then beat repeatedly with hammer.
Haynes: This is a tight fit.
Translation: Clamp with vise grips then beat repeatedly with a hammer.
Haynes: As described in Chapter 7...
Translation: That'll teach you not to read through before you start. Now you are looking at scary photos of the inside of a gearbox.
Haynes: Pry...
Translation: Hammer a screwdriver into...
Haynes: Undo...
Translation: Go buy the giant economy size of WD40
Haynes: Retain small spring...
Translation: PINGGGG - "Jesus, where the hell did that go?"
Haynes: Lightly...
Translation: Start off lightly and build up till the veins on your forehead are throbbing then clamp with vise grips then beat repeatedly with hammer.
Haynes: Check Weekly...
Translation: If it isn't broken don't fix it.
Haynes: Routine maintenance...
Translation: If it isn't broken, it's about to be. Be warned.
Haynes: One Wrench Rating (difficulty guide).
Translation: An infant could do this... so how did you manage to f*ck it up?
Haynes: Two Wrench Rating (difficulty guide).
Translation: Now you may think that you can do this because two is a low, teensy weensy number... but you also thought the wiring diagram was a map of the Tokyo underground (in fact that would have been more use to you).
Haynes: Three Wrench Rating (difficulty guide).
Translation: Make sure you won't need your car for a couple of days.
Haynes: Four Wrench Rating (difficulty guide).
Translation: You're not seriously considering this are you?
Haynes: Five Wrench Rating (difficulty guide).
Translation: OK - but don't ever carry your loved ones in it again.
Haynes: If not, you can fabricate your own special tool like this...
Translation: Hahahahahahahahahahahahahahaha....
Haynes: Compress...
Translation: Squeeze with all your might, jump up and down on it, throw it at the garage wall, then find some vise grips and a hammer...
Haynes: Inspect...
Translation: Squint at really hard and pretend you know what you are looking at, then declare in a loud knowing voice to your wife "Yep, as I thought, it's going to need a new one"
Haynes: Carefully...
Translation: You are about to suffer deep abrasions.
Haynes: Retaining nut...
Translation: Yes, that's it, that big spherical blob of rust.
Haynes: Get an assistant...
Translation: Prepare to humiliate yourself in front of someone you know.
Haynes: Turning the engine will be easier with the spark plugs removed.
Translation: However, starting the engine afterwards will be much harder. Once that sinking pit of your stomach feeling has subsided, you can start to feel deeply ashamed as you gingerly refit the spark plugs.
Haynes: Refitting is the reverse sequence to removal.
Translation: Yeah, right. But you swear in different places.
Haynes: Pry away plastic locating pegs...
Translation: Snap off...
Haynes: Everyday toolkit
Translation: AAA Card & Mobile Phone
Haynes: Apply moderate heat...
Translation: Unless you have a blast furnace, don't bother. Alternatively, clamp with vise grips then beat repeatedly with hammer.
Haynes: Index
Translation: List of all the things in the book, except for what you need to do
Biohazed posted this on magmalliance.com and I just figured I'd have to share it with you.
Old Dec 13, 2010 | 08:20 AM
m3ch's Avatar
m3ch is on a distinguished road
hahaha thats great i dont need a Haynes manual my friends dad is a trucker and a uncertified mechanic i just go to her house and ask him, hes usually right
theres atleast 3 people in the garage when working Him (the trucker), his son in law, and the person working on the car.........and thats just about how working on any car works........if you cant turn it, get a hammer..........
Old Dec 13, 2010 | 11:15 AM
Sturg's Avatar
I amaze myself at what I can make work after I hit it with a hammer
kevinph
Feb 25, 2019 09:24 PM
chris015
Aug 3, 2011 08:17 PM
Jonboy
May 16, 2011 08:49 AM
BonestockZR2
Nov 2, 2009 07:00 PM
kiwiblazer
Oct 14, 2008 12:02 AM
