I flooded my Blazer in a HUGE pool of water and need ideas/help!
Old Sep 10, 2011 | 09:47 AM
HigherPower's Avatar
HigherPower is an unknown quantity at this point
You could have water in it and the TheRandom1 is correct you should check all of them diffs are easy just stick your finger in and pull some fluid out you will see if it has water in them, I did the same to a Mazda tribute , just ended up replacing plugs (needed it) oil/air filter change and it started up, It had about 2qts of water in the oil pan and about 1 qt in the engine. I cranked it with the plugs out and shot the water out then used a small lenghth of clear tubing attached to my wet/dry vac and removed any left over. Toys fixed! = reason for blazer purchase wife got mad at me 4wheelin' the nice not paid for one!
Hopefully you will get it back running smooth
jazzylee77
Aug 24, 2015 08:02 PM
toaks1
Aug 20, 2012 08:14 PM
247monster
Apr 6, 2012 05:14 PM
chilecol
Jul 29, 2011 11:38 AM
jettmech2002
Sep 26, 2009 11:59 AM
