Looking for a forum like this for cars
Old Sep 24, 2012 | 12:29 AM
icemanthe1's Avatar
icemanthe1 is an unknown quantity at this point
Default Looking for a forum like this for cars
I am getting a code of PO335 on qa 2004 chevy malibu 3.5 my tech II seems to not find this engine, so not sure of the code since I used a reading for a 3.4 which did show all the data in 1 and 2. So looking for some advice about that engine and where the Crank position sensor is, I thought it would be up behind the starter but not there. Any advice to a forum site that is as good as this one for GM cars thanks.
Old Sep 24, 2012 | 06:25 AM
trobbins's Avatar
either between tanny an oil pan or on the back of the block on the firewall side be on bottom left side of motor
Old Sep 24, 2012 | 06:41 AM
rriddle3's Avatar
Old Sep 24, 2012 | 08:04 AM
icemanthe1's Avatar
Thank you for both answers but the PO335 code still bothers me most are PO336 either way I need to test it once I find it. Thanks again.
Old Sep 24, 2012 | 08:19 AM
95BlazenLT's Avatar
95BlazenLT is on a distinguished road
Sounds like you have a short either at the crankshaft position sensor (back of engine on the block) or at the camshaft postion sensor (top right of engine) or a short to ground... P0335 code is the pcm not receiving pulse signal from said componets... Good Luck!
old skool luvr
Oct 7, 2012 08:26 AM
zakm0n
Jan 10, 2011 11:42 AM
thevair65
Jul 8, 2007 10:39 AM
speeddemon560
Mar 2, 2007 12:52 PM
speeddemon560
Feb 10, 2007 12:55 AM
