This mechanical but not a blazer were stumped
Old Mar 2, 2014 | 11:59 PM
slayer3006's Avatar
slayer3006 is on a distinguished road
Default This mechanical but not a blazer were stumped
I have 07 Pontiac Torrent AWD. Scanned it, no codes. So why on my cluster display do I get: service stabilitrac, AWD off, service traction control along with ABS, and traction control lights. So we took it to the garage and was put on the most current computer and it said it was a front wheel bearing. So we replaced it and nothing. Now it had service tire pressure monitoring system and says my rear passenger tire is flat, but is fine. Dunno how I'm making it around this winter, my poor blazers sitting need money I don't have to get street legal still runnin strong though.
Old Mar 3, 2014 | 01:36 AM
Diaita's Avatar
I didn't know a scan tool could detect a bad wheel bearing. What about a bad wheel speed sensor, or a corroded plug for a wheel sensor?
Old Mar 3, 2014 | 07:55 AM
The code was likely concerning the WSS (wheel speed sensor) as Diata pointed out. The issue could be with the sensor itself (most of the time they are just dirty or have an improper air gap - both of which are repairable without replacing the sensor or the hub assembly), connections between the sensor and the EBCM (electronic brake control module), and/or the wiring itself. Rarely is the wheel hub assembly at fault for WSS codes.
If the shop just threw parts at the problem, I would go back and rip into them good as they didn't do their job at diagnosing the issue. If they do not want to work with you on properly fixing the issue at little to no cost to you, call the BBB (Better Business Bureau) and file a complaint against them.
Old Mar 3, 2014 | 01:58 PM
Diaita's Avatar
This sounded like I was being a smart ***...I wasn't trying to be, it just came across that way, sorry.
Anyway, a good shop will certainly stand behind their work. Bring it back and they should fix it properly.
Old Mar 3, 2014 | 03:29 PM
slayer3006's Avatar
Default Will look at that
That's a new idea I'm gunna look into that. Let's hope haha. Thanks for your input.
Old Mar 3, 2014 | 10:53 PM
slayer3006's Avatar
Default Figures
No such luck. Torrents are electrical nightmares. At least I can say it's my wife's car.
youngbloodsno111
Mar 23, 2019 07:00 AM
tallbump
Mar 15, 2015 07:48 PM
John Mongelli
Apr 27, 2010 12:32 AM
ScottWV
Jan 18, 2010 09:55 PM
azn_hispa_dude
Oct 24, 2007 12:11 PM
