Transmission & transfer case
Old Jun 14, 2018 | 11:12 PM
A29noland's Avatar
A29noland is on a distinguished road
Default Transmission & transfer case
I have a 2003 Chevy Silverado 5.3L how do I find out what transmissions and transfer cases I can replace it with. As in the years and makes and models of rigs that would have a replacement transmission and transfer case. I know the transfer case model is 261LDGM but don’t know transmission model
Old Jun 15, 2018 | 05:56 AM
Transman304's Avatar
Transmission wise you could use a 1998-2003 with the 5.3. Can’t speak on the t-case.
Old Sep 15, 2018 | 10:39 AM
awesomeamerican1's Avatar
awesomeamerican1 is on a distinguished road
There should be a tag on the transmission and the transfer case which will tell you what they are. More than likely transmission is a 4L60E and transfer case is probably a NV241. Like transman said you could probably use anything 98-03 but be weary of the slight differences identified in the video as some bolt holes are different. Transfer case doesn't really matter too much you can get an adapter from a junk yard as long as output and input spline count match.
e
Hess13x
Jan 28, 2019 05:25 PM
