Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
2-3 inch drop o2 extreme
Old Oct 31, 2009 | 08:07 AM
o2 blazer extremme's Avatar
o2 blazer extremme is on a distinguished road
Default 2-3 inch drop o2 extreme
hi guys im new to this i have an o2 blazer extreme i want a 2 inch drop in the front and 3 inch in the rear ive read on here that an extreme it is different cuz its already lower so i was just wonder what i need for a real 2-3 real drop and im kinda lost any help wud be great thanx gys and if any 1 has pix of it that wud b great 2 thanx
Old Apr 26, 2010 | 08:12 PM
Fzn14's Avatar
Fzn14 is on a distinguished road
I had to do 3' springs in front and 3' blocks in the rear...i did the 2/3 drop and it made little no difference...just as an fyi
Old Apr 26, 2010 | 10:25 PM
RangerG's Avatar
Old Apr 27, 2010 | 07:27 AM
oktain's Avatar
Originally Posted by RangerG
LOL.
Fzn14: Do you have an Xtreme?
Would it be safe to say that 2inch drop springs for a stock 2wd, would have no effect on an Xtreme with a factory 2 inch drop? lol.
If you buy lowering parts, make sure it's for the Xtreme so you get the drop you're looking for. Look into the way the Xtreme is lowered, if it's got front "drop" spindles, then I don't know why the 2/3 drop wouldn't have worked for FZN, which leads me to suspect it's lowering springs from factory. Good luck, and post some pictures up after.
Old Apr 27, 2010 | 11:22 AM
DriftinBlzr's Avatar
DriftinBlzr is on a distinguished road
The Xtremes are 1.5" lower from the factory using lowering coils and leaf springs. Using an aftermarket 3" drop coil will only get you an extra 1.5" of drop.
If you want a guaranteed 2"/3" drop you'll need drop spindles and blocks.
Later, Doug
Keeler
Lifting Tech
22
May 29, 2010 03:53 AM
blazinUP
Tires and Wheels
May 14, 2010 08:06 PM
AK8BLANK
Suspension Tech
Mar 3, 2007 07:55 PM
DS01blazer
Suspension Tech
Mar 22, 2006 12:14 PM
