Suspension Tech Have a question about modifying your suspension? Ask it here.
3 inch drop
Old Mar 12, 2006 | 12:29 AM
DS01blazer's Avatar
DS01blazer is an unknown quantity at this point
Default 3 inch drop
I have a 2001 blazer Lt 4door i wont to get a 3inch drop for it but i am getting 20inch rims with low profile tires what i want to know is if i get the drop with the rims will i still be able to turn or will it rub?
Old Mar 15, 2006 | 03:56 PM
Bgray's Avatar
Bgray is an unknown quantity at this point
Default RE: 3 inch drop
thats all pending on if whoever u get the rims from does there homework. Need a proper backspacing and offset to amke it work. I imagine 7" wide rim the the frotn is about as wide as u want to go. 350 series tires to. Donk305..has got a lowered blazzer with soem big rims...pn them
Old Mar 20, 2006 | 06:20 AM
blazerxtreme1's Avatar
blazerxtreme1 is an unknown quantity at this point
Let me know if you find 7 inch wide 20s!
I dont think you can do 3 inches with dubs, I have a xtreme on 20s w/35 series tire and i still rub when i turn sharp, so i'm about an inch lower that you and all that i'm going to do is one inch up front then i will get into problems so i think 3 inches might be alittle too much, but the lower the better
[IMG]local://upfiles/1452/F05B00B96FF2487684FB7644B7F8C6E8.jpg[/IMG]
Old Mar 22, 2006 | 12:14 PM
DS01blazer's Avatar
Default RE: 2 inch drop
so do you think that a 2inch drop would work.
Keeler
Lifting Tech
22
May 29, 2010 03:53 AM
blazinUP
Tires and Wheels
May 14, 2010 08:06 PM
o2 blazer extremme
Lowering Tech
Apr 27, 2010 11:22 AM
AK8BLANK
Suspension Tech
Mar 3, 2007 07:55 PM
