Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
Cutting coils
Old Sep 21, 2012 | 06:57 PM
antman94's Avatar
antman94 is on a distinguished road
Default Cutting coils
I just bought 2 inch drop coils for my 2000 Chevy blazer ls. I want just a tiny bit more than 2 inches so im wondering if I can just cut 1/4 of a coil? is the safe? and will it still mount ok? thank you.
Old Sep 21, 2012 | 09:17 PM
warthogdriver's Avatar
look into if you should cut top or bottom. i know that some say go for it some say no. i have been looking into this for my mustang and from what i found...yes you can do it. it seems like hot rodders have been doing this for years.
but dont use a torch or anything like that with alot of heat. you can use a cut off wheel or if you feel manly a hacksaw ( )
like anything you cut...start small. i found that on mustangs if you cut off one coil you drop 1 -1 1/2" inches. so i am going to cut off 1/4 coil at a time till i get where i want to be.
Old Sep 21, 2012 | 11:06 PM
xgiovannix12's Avatar
I wouldn't even try with an hack saw lol
If you do im coming to watch
Old Sep 22, 2012 | 01:36 AM
antman94's Avatar
Haha yeah no way I have a cut off wheel for that!! as for which side, I read that it doesnt really matter because the spring is the same on both ends. But I think Im going to cut the top just because of how you need to index it with the drain holes on the bottom.
Old Sep 22, 2012 | 09:28 AM
cleburne red's Avatar
Definitely start small! With cutting coils, a little goes a long way. Also, some springs are progressive, so cutting the wrong end can really mess the ride up. While it's not the best way to lower a car, people have been doing it for decades, and if done right shouldn't screw anything up too bad.
Old Sep 22, 2012 | 09:33 AM
50lb_cat's Avatar
When you cut the coil you need to cut one whole coil at a time. And definetly use a cutting wheel lol. I did it on my 63 fairlane, 1 coil gave me about 2 inches of drop. It does ride a lot harder now but looks badass.
Old Sep 22, 2012 | 05:42 PM
antman94's Avatar
Default Big idiot
Well guys, I think I am THE BIGGEST IDIOT on the forum right now. I made small cuts with a grinder just to mark where I want to cut when I get my Cut off wheel back from my dad. well, stupid me made one cut at the the bottom of one spring, and on at the top of the other.. Is there anything I can do for this? Thanks alot! Name:  120922_0006_zpsf9b97ab4.jpg
Old Sep 23, 2012 | 07:10 PM
Not sure if there is any way to fix this... Ill let ya know if i think of any thing.
Old Sep 23, 2012 | 07:30 PM
if the top and bottom of the springs look the same...it "shouldn't" matter
*****i am not a suspension expert*****
Old Sep 23, 2012 | 08:06 PM
im not sure I think the tops are different.
Edit: the kits are pretty cheap.
http://www.ebay.com/sch/i.html?_trks...rings&_sacat=0
chadillac85
Apr 24, 2011 07:28 PM
guitarman
Lowering Tech
Mar 16, 2008 10:54 PM
stiltz1634
Suspension Tech
Mar 24, 2007 04:27 AM
CashSax
Feb 3, 2007 06:07 PM
BlaZeR FXB1581
Suspension Tech
Apr 3, 2006 02:52 PM
