Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
Lowering a 4wd blazer/jimmy
Old Apr 12, 2007 | 03:30 PM
vagnozzi's Avatar
vagnozzi is an unknown quantity at this point
Default Lowering a 4wd blazer/jimmy
I LOVE the looks of a Blazer xtreme and how they sit (much lower than my 4x4 Jimmy), but if you do that to a 4wd truck, does it handle worse in icy/snowy conditions?
What's the average drop on these kinda trucks? Mine is a '01 SLS 4x4, and I'd love the stance of a Blazer xtreme, but will it affect handling? How low is too low for factory wheels?
I'd appreciate any input on this subject, I'm sure its been discussed a thousand times...lol
-Chris
Old Apr 12, 2007 | 06:23 PM
nj4x4blaze's Avatar
Default RE: Lowering a 4wd blazer/jimmy
Belltech makes a 3/3 lowering kit for your truck.
Old Apr 12, 2007 | 11:05 PM
vagnozzi's Avatar
I don't see anything for my truck on that website... []
Old Apr 12, 2007 | 11:08 PM
agent305's Avatar
agent305 is an unknown quantity at this point
i dropped mine 4"f 5"r . i had to drive home in a snowstorm like a month ago and it drove normal
Old Apr 13, 2007 | 02:46 AM
TheBrettster's Avatar
TheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond repute
ball joints are gonna wear HELLA FAST.
Old Apr 21, 2007 | 04:56 PM
simply2low4u's Avatar
simply2low4u is an unknown quantity at this point
youd be suprised. Everyone thinks youll blow through the ball joints but not really. Just get an alignment once you drop it so your not blowin through tires and if you wanna do a ball joint switch go with some moogs
Old Apr 11, 2008 | 10:04 PM
dubb_05's Avatar
dubb_05 is an unknown quantity at this point
you shouldnt wear balljoints that bad tho by lowering but if you raised it would wear them bad ( from what all I understood anyways )
Old Apr 12, 2008 | 01:04 AM
blazin97's Avatar
blazin97 is on a distinguished road
you can do it easy by taking out the torsion key bolts out and buying lowering blocks. It should drop the front anywhere from 2-4 inches and you can get 1-4 inch blocks.
Old May 1, 2008 | 11:32 AM
Dropdblzr2000's Avatar
Dropdblzr2000 is an unknown quantity at this point
I lowered my 2000 LT w/ torsion keys and 3inch blocks in the rear but i recommend the 2inch blocks if you do the torsion in the front. Get an alignment in the front. And for the record it will handle some corners.
Old May 11, 2008 | 05:33 PM
johnnyr's Avatar
johnnyr is an unknown quantity at this point
My '99 is lowered two inches, t-bars in front, blocks in back. I just replaced the stock ball joints and they weren't really worn out. The CV joints were noisy, and I figure the lowering caused them to wear more than usual.
With 18" wheels and wide tires she handles nice!
