Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
lowering a 93 blazer s10 4x4
Old Jul 27, 2009 | 12:49 AM
wallen_steven's Avatar
wallen_steven is on a distinguished road
Default lowering a 93 blazer s10 4x4
hello i was wondering if u could help me with somthing i have a 1993 blazer s10 4x4 and i was wondering what i had to do to lower i and what i need and were to get it i thin i want 3in front and back maybe 3 in front and 4 in back no sure u think u could geive me some info i got pics on my page if u wanna look at it to help u see it\
thanks
Old Jul 27, 2009 | 01:49 AM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
to lower the front all you have to do is back out the tbar bolts and then add lowering blocks to the rear.
Old Jul 27, 2009 | 02:27 AM
i know im gonna sound really dumb saying this but exacly how do i back out the tbar and how do i add the lowering blocks or would it be easier to buy a kit
Old Jul 27, 2009 | 12:06 PM
mikeinwi's Avatar
a kit for a 4x4 is waste of money IMO. to back the bolts out just look up the torsion bar crank in the DIY section and just turn your bolts the opposite way and the blocks are fairly easy to install.
Old Jul 27, 2009 | 01:42 PM
oktain's Avatar
the blocks go between the axle and the leaf springs... fairly straight forward. I've considered doing the same thing, but the clearance is nice when I get boxed into parking lots and the couple of times I go off-road.
Old Jul 27, 2009 | 02:52 PM
ok so i have to back out the bolt on the tbar and then i put the blocks between the leaf springs and the axle now i have to more qustions the truck should be rasied up first right instead of it being on the ground and the second is should i get new shocks after this is done.
Old Jul 27, 2009 | 03:49 PM
oktain's Avatar
It's recommended you get shocks, and an alignment for that matter, but the shocks aren't necessary, just a good idea. (Don't ask me why) You'll probably have to trim your bump stops too.
Old Jul 27, 2009 | 07:50 PM
and when i do it should it be on jack stands or should it be on the ground or in the air on a lift ??
Old Jul 29, 2009 | 11:10 PM
mikeinwi's Avatar
i would put the blazer on jack stands. if you look through the How to on the tbar crank itll tell you exactly what to do, but youll just have to turn your tbar bolts the opposite way(back them out) to lower the front.
Old Jul 30, 2009 | 08:16 PM
thanks for the advice
error_401
Dec 10, 2013 04:36 AM
beaver50
Dec 31, 2011 02:14 PM
chris015
Lowering Tech
Jun 6, 2011 10:43 PM
Chesnuts5
Lowering Tech
Nov 5, 2010 03:11 PM
blazed16
Lowering Tech
Mar 30, 2010 04:34 PM
